Fuel Distributor PLEASE HELP !!!
(In Topic #233198)
Mk1 Golf Gti 1.8 DX engine Fuel Distributor help
I have searched online for 1 the part number of the 1 I have (0438100121) brings up a Bosch fuel distributor for a ford xr3i. This part was fitted to the car for a number of years before it came of the road.
Does anyone have the original part number for the 1983 DX engine?
Does anyone know a place I can send it off to be refurbished or renewed?
The mechanic said everything else is working ok.
The car has burnt out 3 fuel pump relays trying to diagnose or get this sorted, would a knackered fuel distributor cause this to happen?
He said on 1 occasion the fuel pump stayed on and the bores got filled with petrol, said the plunger was stuck. The plunger now moves but no fuel comes through.
Sorry for my poor explanation I am not mechanically minded
Any help is appreciated
Thanks in advance
Carl Jones said
Could these people help? Bosch K-Jetronic
Thank you, I have emailed them but they are closed until July.
I had both my fuel metering head and warm up regulator overhauled by them.
I personally would suggest carrying out the fuel tests as per the Haynes manual before spending a lot of money on replacing or overhauling parts. The brown Haynes manual is really good.
Best to check the fuel metering plunger, auxillary air valve, air sense plate, injector spray and do the pressure test as per the manual.
Metering Unit
£310 + vat. Full rebuild with a one year warranty (warranty does not cover failure by contamination of dirt and water).
Build time approx. 4 weeks. Return UK shipping £12.00 + vat.
WUR
£140.00 + vat.
The pressure yest has been done as per the manual.
I shall tell him about the relay.
