Dashboard woes & fed up
(In Topic #240949)
![adolf in the usergroup ‘Local’ adolf in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
Thought I cured things but then a bulb on the instrument cluster now in-op so will have to remove cluster again which worries me as more times I disturb it the more likely it'll get damaged.
I changed the light switch as the rheostat seemed faulty which cured a couple of things but now when I turn on lights the Rev-counter stops working. 🤷🏼♂️
Changer rear springs in the end as existing ones seemed a bit saggy and car squatted down a bit at rear.
Oh and left car for couple of weeks and now no brakes 🤷🏼♂️🤷🏼♂️
This resto is fighting me all the way !! 🙁
It's 40 years old now and was looking forward to a bit of motoring around this week tax free but too many jobs o/s now (again!!)
![6C2B5B6F-1CA5-44CA-A93C-6B7F5206CD7F.jpeg 6C2B5B6F-1CA5-44CA-A93C-6B7F5206CD7F.jpeg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_1024/v1687115034/uploads/attachments/648f551793171.jpg)
I have found that Plumping the connectors, (using one piece of electrical tape on the connector tongue works wonders, as well as an addition to splice a ground from the Pin side of the connector to the frame directly behind the Cluster to be a wonderkin.
I would also verify that tach has a good ground as well so you might want to run a continuity test between it and ground on pin 2 of the mylar (brown wire).
That's what happened to my car when my thin earth lead broke.
Maybe I've got this all wrong but there is no plain brown wire that's free coming out the loom near the rocker - only this brown/white.
I'll get a pic up tomorrow.
The LED on the instrument cluster not working neither and actually nor does the fuel gauge come to think of it. There's no power to the tank sender plug connection as I've checked the voltage with a meter
Such fun ….
The Sender is a Rheostat or Potentiometer, that varies the resistance of ground to your sending gauge.
One side of your Sender is ground, the other side is varying resistance to the gauge.
Testing the wires.
unplug the sender plug. Use a 9Vdc battery.
negative on the brown wire in the connector, and the Positive to the violet wire.
Your fuel gauge should rear dang near full. if it does then you have just tested your wires, if not.
Test your gauge the same way, if it doesn't deflect then gauge…If it does then you may have a connection issue
mylar break on your clocks or bad 10V stabilizer.
You have a ground wire on your clocks it is Brown.
Take an inline Scotch-lock wire splicer and tie it to frame behind the clocks.
You also need a earth wire from your Valve cover to your Coil bracket.
![Screen Shot 2023-10-11 at 6.32.41 PM.png Screen Shot 2023-10-11 at 6.32.41 PM.png](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1697063590/uploads/attachments/652722a5b15fd.png)
![Screen Shot 2023-10-11 at 6.32.41 PM.png Screen Shot 2023-10-11 at 6.32.41 PM.png](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1697063596/uploads/attachments/652722ac0b324.png)
I think my problem is that I've a brown/white wire that I've earthed to the rocker cover. I've seen no plain brown wire or broken one to use - only this brown/white in pics. This wire comes out the bit of loom that serves the reverse switch/sensor on side of head.
I've put an earth lead from coil bracket to rocker cover in pic.
![137D2E7D-2C09-4D32-974A-35128AFB9ABA.jpeg 137D2E7D-2C09-4D32-974A-35128AFB9ABA.jpeg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1697273208/uploads/attachments/652a55763032c.jpg)
![52139A22-C612-4461-9349-4C222DAB1E50.jpeg 52139A22-C612-4461-9349-4C222DAB1E50.jpeg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1697273212/uploads/attachments/652a557b36e82.jpg)
![4176989B-7DD2-4932-8F9B-4A8A27861F8F.jpeg 4176989B-7DD2-4932-8F9B-4A8A27861F8F.jpeg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1697273215/uploads/attachments/652a557e111d6.jpg)
![](https://uploads.tapatalk-cdn.com/20231015/84dc879f77ff3946c5bf02238814649c.jpg)
My wire from the coil bracket is the thicker type but see if yours works?
![](https://uploads.tapatalk-cdn.com/20231015/c9dfe074b70e7633f4d2428e6be4ef63.jpg)
Glad I've got the right wire anyway
They only start with good grounds.
Start at the following Brian's Quick Test.
Briano's Quick Grounds test. | Volkswagen Owners Club Forum
If you still have the OEM cables on your car, chances are they are TOASTed, CORROded, and. going to be the Pain in your Keister for intermettents.
I would add that it wouldn't hurt you to run new Positive Cables from the Battery to the Starter, Alternator and Fuse Panel.
When I was Getting mine back to OEM. I used 2 off the Shelf shielded Cables for the Negative, one Battery to frame and one Battery jumper from frame to the engine/Tranny.
I also got the Negative battery cables that had the 2 spare grounds so I could off load the Added nut grounds to a soldered heat shrinked connection so I only had to worry about the nut.
I also did the same for the Battery so I could get my extra wires off the Positive post nuts.
Where I connected my Battery to Frame and Frame to engine on the frame horn stud I cleaned the Stud, Sprayed the Back side of the Battery connector then added the Jumper with a large Fender washer that went over the stud to the frame, battery cable end, then frame cable end, large fender washer, lock washer, and nut. Once finished I sprayed the Frame connection with additional Corrosion preventor.
That way I didn't have to look at it again for a years.
Also take a wire with Ring connectors from your alternator case bolt to the engine lifting EYE bolt.
In the rear of the car, I took the tail lights ground and ran it to one of the bumper bolts with a large ring connector for each side…Bulbs seemed a tad bit brighter.
1. No light bulb working on light switch
2. LCD not coming on
3. No fuel gauge
With point 1 - I've a 12v reading between the red & brown on the plug for the light switch plug but no reading for the bulb holder itself - tried new bulbs so electrical issue. Is there an issue with the black/yellow ?
I've padded out the connector mount so the instrument connector multiplug fits into the myler snugly but I've still not a LCD display. This partly comes on but then fades to nothing. Not sure why?
Hoping point i3 is connected to above, but I need to check the fuel sender unit in the tank
If not then you have a wiring issue between the sender wire, and the gauge possibly.
Also check the 10V stabilizer for Ground on the Screw, then 10V one one lead and B+ battery on the other.
Hooked up the car battery on and lcd comes on then fades again - would this be the stabiliser - so you say Briano I need to put the black/neg on to the screw holding the volt stabiliser onto rear of cluster and live to see the reading - is that the correct way ?
Last edit: by adolf
So is this the 10v stabiliser that's screwed into the back of the cluster with the 3 prongs?
![4A5FCD51-CB66-4AC9-8752-FA4E9FFEF1F5.jpeg 4A5FCD51-CB66-4AC9-8752-FA4E9FFEF1F5.jpeg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1701003742/uploads/attachments/656341dc62b97.jpg)
![7F675268-3923-416C-AA31-B2CE8248A46C.jpeg 7F675268-3923-416C-AA31-B2CE8248A46C.jpeg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1701003747/uploads/attachments/656341e2a7ac9.jpg)
![5DC03EF2-0567-4CEE-BB1A-BAA7C8121F70.jpeg 5DC03EF2-0567-4CEE-BB1A-BAA7C8121F70.jpeg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1701003751/uploads/attachments/656341e60d649.jpg)
LCD's fading is usually a connection issue on the LCD to board connection.
Some one here has a link to know issues with the MFA's.
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/64image.jpg)
Life Member
![Dano in the usergroup ‘Moderators’ Dano in the usergroup ‘Moderators’](https://vwgolfmk1.org.uk/themes/default/images_custom/OeIGBY0.png)
![Dano in the usergroup ‘Paid Member’ Dano in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![Dano in the usergroup ‘Regional Hosts’ Dano in the usergroup ‘Regional Hosts’](https://vwgolfmk1.org.uk/themes/default/images_custom/MkOEmwK.png)
![Dano in the usergroup ‘Old timer’ Dano in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
