Click click click sound ?
(In Topic #203128)
Stone caught in and round front brake back plate?
Handbrake cable lose near the rear wheel and catching the tyre?
It's really hard to guess what it might be, is the sound inside or outside the car.
Now with that said, have you replaced your main battery to earth, and earth to engine/transmission cables yet?
You could be having a ground interference issue, as if yours are still original then they are at least 30 years young, and that the fact that they are open stranded Cables are subject to road grime and battery outgassing that effects the current capabilities of the wires…..
Make sure that there are no wires that are rubbing against the steering shaft as well.
1992 MK1 Golf GTi Rivage - Classic Blue Metallic - Long term project
1991 MK1 Golf GTi Rivage - Classic Green Pearl - Sold
BAZ-GTI said
Hey sorry been away for a bit, briano could you explain more about the earth issue, as I have replaced terminals as old were knackered but more about the wiring so I can make some checks thanks again, MrP, Il remove the caliper and see what it does any corrosion and stuff, thanks again
I have a thread about grounds (you call earth) effects and the running of your car. I will post the link as well as a link to CIS grounds.
I have over 40 years in the Computer Industry, Aircraft as well as Mainframes of old.
Riddle me this?
What do Divorces, Great Coffee, and Electrics all have in common?
Wait.
Good Grounds. some times we need a dose of humor.
Ground effects and the repair of your car. | VW Vortex - Volkswagen Forum
Electrical System
These are for Cabriolets, 80-93. They cabby is a MK1
and should have most of all the grounds covered.
I usually jack the rear and wiggle the tire for play, lots of play then the bearing could be bad, or more common is that the nut isn't tight enough tighten the nut and roll the tyre to see if it still growls, or has lateral play.
When I suspect a bearing failure, I usually do the Bearing, Wheel Cylinder, and rear shoes so I don't have to worry about the rears for a while. If you haven't replaced the rubber rear brake hoses, now would also be a good time to do that as well.
When replacing the Wheel Cylinders or hose I find that by wrapping the screw threads on the Hose fittings, wheel cylinder side and attachment to the hardlines with Teflon Tape including the bleeder port nipples makes sure that I don't have an issue later when I need to bleed the lines or replace things…. When covering the bleeders with Teflon Tape, be sure that your port is open by pricking a hole in the tape….or uncovering the port.
