Bottom end growl/rattle
Got my 1.6 gti up and running after restoration and it's developed a growl/rattle in the bottom end which sounds like it's from the gearbox side of the engine.
When ticking over you can't hear it but the more and more revs the louder you can hear it.
Dropped the oil out which is new and there was no metal filings to be found, carried on to drop the sump which had some white residue and check the crank with no obvious movement.
Oil pick up had stuff on it but wasn't metal.
Took the closest crank cap and piston cover off and couldn't see any scoring either.
I'm a bit unsure where to go from here to be honest if anyone has had similar issues I'd love to hear them.
Also are these bolts on the crank covers stretch bolts and need renewing? Cheers Jason IMG20230916164523.jpg IMG20230916165843.jpg IMG20230916180206.jpg IMG20230916180217.jpg IMG20230916180945.jpg IMG20230916181006.jpg IMG20230916180513.jpg IMG20230916180517.jpg IMG20230916180520.jpg
what's the oil pressure? does the noise go away if you depress the clutch - yes I know this is an old thread
