All Fuel injectors leaking
(In Topic #216815)
It starts awesome cold, but takes a few cranks to start hot, and will smell like fuel. Both my dad, and ex highschool shop teacher said it seems like injectors.
I pulled my injectors to test one at a time. All 4 will leaks drops, dripping about every 4 seconds, and continue to do so for a while. My question is, since all 4 leak, is if certainly the injectors? Or could it be something farther back. The air flow plate was in good shape.
Also, since injectors are about $250 for the cheapest set up here in Canada, is there any hope to clean them? Looking online I see most people say nay to cleaning a mk 1 injector. Why is that? Thank you very much.
But you will need a new set of o-rings.
1 maybe 2 cans of Berrymans b12 cleaner
see: CIS Injector Cleaning, Seal and Holder Replacement
Once you know the Injector is clean and sprays correctly, then you can proceed to look further as in place all 4 injectors in a ball jar and watch the spray pattern to see if they are still leaking after the cleaning.
Turned out to be the pressure plate rest position was too high. I lifted the plate and bent the pin down a bit, as per the Haynes manual, and no leaking now.
That solved that.
