vw garage south west
(In Topic #218655)
I had a engine put in by an apparent top vw garage, after months of waiting I got the car back not running correctly and has pretty much been sat up ever since (5 years or so) I've tried to start it to no avail ok just need someone who is capable to have a look and either get it running or let me know the engine as I expect is a bag of .if anyone can help me in the bristol southwest area I would appreciate it greatly thanks also if this makes sense to anyone can you please let me know what combination it is but I was told it's top 1.8 16v mk2 and bottom 2l 8v mk3 I have no idea what parts I need i.e. mk2 or mk3 starter motor ect
There will be a engine code just below cyinder 3 spark plug on the engine block and that should tell you what engine block is in there.
What parts do you need as most service bits are the same for the engine.
I would also start soaking those rocker cover studs as they look rather rusty….
That cam belt looks like it’s seen better days, I would recommend fitting a new one and new cam belt tensioner before starting the car.
thanks again, clive
DANBOY.
Mk1 Golf cabrio "Golf+ absolutely cabulous"
fresh 20vt rebuild well underway
https://vwgolfmk1.org.uk/forum/index.php?page=topicview&id=projects%2Fyour-mk1-golfs_2%2Fmy-old-white-cabby#post_1402754
DANBOY said
Retro Resus in Bridgewater if you get stuck with it![]()
Have you used these people and would you recommended them? I need a little welding on my Mk1 Scirocco and wondering if there work was any good?
Tom done the 20vt conversion on my Mk1 cabby his work is top draw
He also built my 1.8t ibiza custom sidewinder with a gtx2867r making 411 bhp also done my roll cage converted it to a 6 speed mk5 Gti box lsd forged engines on both cars his welding is fantastic
Honesty he is a proper nice humble bloke to deal with
I got hundreds of pics on my insta and Facebook
Insta Dan66jones
DANBOY.
I've been looking into the 1.8 20v turbo but undecided which engine code to go for performance wise and ease if fitment (if any different from each other) or if there is any other engine that's easy to fit and similar performance wise I would appreciate any advice, also would it be better to say get a full mk4 gti turbo or buy separately, thanks in advance for any advice
The ecu’s are so basic and hardly anyone wants to tune them any more
Ideally you need to be running a me7.5 ecu set up so bam engine code or amk I think
Best one to get ideally is a 225 Audi TT set up or a Leon Cupra r with the ko4 set up rather than the ko3 golf easy 280 bhp
DANBOY.
