mercedes brass fuel injectors, any good?
(In Topic #156770)
These are the original injectors.
Not had any issues with them, but not sure if I am looking at good ones or not. Should I just refurb or replace like for like?
I would ideally like the mercedes brass ones but concerned they won't match the fuel lines from the metering head(?) The ones in the pic are stock as far as I know.
The only fuel lines actually changed are the main ones from the underside (flexi ones from Mark Carter).
If it helps, here is a pic of the injector seats in the Head too:
Many Thanks
test yours, if they spray nicely no need to replace. if they're bad, then buy new ones. clean them up and check the part numbers, if its an earlier MK1 they are the same thread as the merc brass ones
Thanks for the response. It is a 83 dx though so not so early. :-)
Me and workshop decided to tidy up the current ones and see how we get on, as you suggested.
Getting the new head and system running right after 10 years has got me a bit anxious.
Ta
