bit-a running prob, mk1 keeps dieing out and crying!!
(In Topic #73771)
ive nearly crashed a few times…
any advice here?
heres my mk1 anyway….
Life Member
Are the bumpers original or have you replaced them? If so where from cause loads of people on here are after a set!!
Good luck with your problem
Dan
dano- i bought chrome strips from a local auto store that i have applied to normal black bumpers,
you couldnt show some close up pics of those bumper could ya,
where abouts you based?
Darren
Its usually the fuel filler neck that rusts and deposits rust in the tank. As you drive the rust gets stuck to the filter in the tank and blocks the flow of petrol. Some people remove the filter in the petrol tank by first removing the sender unit at the top of the tank to gain acces to it then break it off. You need to remove the back seat first though. Then you can just ensure you change the inline filter in the engine compartment at regular intervals say once a year.
Hope this helps you.
see main post 'problem solved'
mark
