VDO guages --help
(In Topic #84135)
VDO guages --help
When i start my gti up from cold the oil pressure flies right up to maximum 5 bar and then when it warms it falls to 3 bar,untill you increase revs then it goes upto 5 bar. According to haynes manuel when oil temp is at 80 degrees and revving at 2000 rpm oil pressure should be 2 bar. I'm suspecting the oil pressure sender is suspect.Trouble is these guages and sender unit are an after market extra,think there Audi.Anybody know where to source a new sender?,or any info what could be wrong
I will have a look at reading on mine this morning. Have the same VDO gauge.
:wink:
:wink:
Mine is running at a tad under 3 bar. So I think you gauge is OK.
Cheers for the info
Results same for my car GTI DX engine, Audi VDO guages. I think the 2 bar spec is absolute minimum on a worn engine.
cheers for that at least i'm on the right side then,better than no oil pressure
