No spark at my mk1 golf GTI plugs!
(In Topic #137294)
Just found ou ther is no spark at the plugs, ive new leads ,plugs, dizzy cap, rotor arm.
Swapped coil over and ignition mod, but still no spark,
Help please
Thanks guys, Its 1983 GTI, not sure exactly what engine, though i know it has the early shim tappets.rubjonny said
check you have 12v to the black wires on coil with ignition on and when cranking
I have power to the coil, but its weird cause when the car wont start if i pull off the 12v supply to the coil then re- attach i can see the coil lead spark again & here the pump prime, its almost like it's re setting?
Any more help please
check all the wiring between the spark unit and the hall sensor too, pull back the rubber boot from the hall plug to make sure its not cracked up where you cant see. look over the loom for any insulating tape, previous bodged repairs always the 1st thing to check for when you have a wiring fault!
Will check tomorrow, this is all good, update tomorrow thanks palrubjonny said
points towards a faulty hall sender or spark control unit id say
My Golf is up & running.................................
The hall sensor in the dizzy had decided to stop as and start as and when it wanted, it nearly sent me crazy, in the end its a £30 fix, so dont give up on your classics kids.
