New golf, same problem
(In Topic #117793)
edit:
sorry kind of in the wrong bit of forum and the problem with the last one was the wiper motor staying on i think and draining power but pretty sure its not that on this un.
can someone run me through a couple alternator checks please, would try searching again but took me ages last time and in a bit of a rush as i've gotta be up at 5 for work.
~Madferret
Mk1 1457cc 5door GX '83
\'83 Lhasa Green GX 1457cc
\'53 Mk4 Golf R32, Deep Pearl Blue
\'00 Kawasaki Ninja J1 ZX6R
\'92 B3 Passat Estate 1.6td (Now breaking) 😭
Member 125 - 2005
while i have had it the car always drove 100% the only thing i can think of , like i suggested in your pm, was sometimes the fan belt did squeel a little . have you checked the belt ? also check how tight it is . i wouldn't have thought it is anything major , change your belt and re-tension it .
and the ciggie lighter doesnt work which meant no sat nav getting home lol
Member 125 - 2005
~Madferret
So any reading you get is dependant on what voltage the battery is putting out
Anyway you already know you have a battery draining problem and you'd be suprised what current some radios will draw when off.
How long exactly are you leaving it? The only way to really check it without a load bench is to seperate alternator and battery. Do you have an ammeter to measure the current draw from the battery?
~Madferret
CAMPAIGN-HELIOS BLUE-POSSIBLY SEEN IT ON CHRIS BARRIES(RIMMER IN RED DWARF) MASSIVE SPEED PROGRAMME?!!!
Member 125 - 2005
Website Manager
'81 1.8T
BMW R1200GSA
Caddy 2k 1.8T
BMW R1200GSA
Caddy 2k 1.8T
i'm gonna swap the alternator off the other car onto this one and see if that works then nice shiny new alternator for the gti.
Bump Starting it virtually every time at the moment. I've got a brand new battery, Ive secured all wiring and checked for breaks in wiring, Ive cleaned up the earth several times and added an extra strap to the srtut tower and a small one from the head. I can only think its the alternator but I'm reluctant to fork out in case its not. If I conquer it i'l be sure to let you know.
