My MK1 (South African <1999 1.8 Carb) just won't fire. Please Assist guys.
(In Topic #152983)
I replaced the coil, ecu without luck. Checked the wirring under dashboard without any luck. I left it standing for sometime till yesterday when I had a look again.
I did the following voltage tests
ECU
1. Pin 2 & 4 = 11.02 v (with ignition on, which means wirring to ecu is ok)
2. Pin 3 & 6 = alternates between 0 & 11.95 v (when turning the engine to its normal direction, which means hall sender (distributer) is working)
Hall Sender
1 . Pin 1 & 3 = 11.02 v (that again told me that the ecu is performing its job)
Coil
1. Pin 1 & Earth = 11.02 v
Unfortunately the car still wont start, plz guys assist, what could be the problem. I will post rusty pictures soon, still struggling with technology.
VW Forever!
The issue now is that the starter turns very slow or won't turn at all. And it drains the battery with jst abt 4 tries.
I even tried jump starting with no luck, instead I could even hear sound changing drastically as if the other car is gonna stall.
What could be the problem now?
