Help, I've NOT Got The Horn
(In Topic #85908)
it is under the bonnet near the nuckle where the colom meets the rack,
hope this helps
Horn
Cheers Stu
Firstly check your fuses. All of them, not just the one you presume is supposed to be the horn.
Only carry on with this if you have some basic electrical knowledge, and the idea of taking voltage readings from circuits doesn't make you anxious. If it does, then possibly best get an auto electrican in.
<<edit>> First and a halfly, get a multimeter or voltmeter, pretty much essential to start looking at electrical faults. Pick one up for under ?10 easily. <<edit>>
2. Test the actual horn by connecting it briefly directly to your battery. If it sounded, then good, the horn definitely works. If not, then this is your problem. Get a new horn! (I know you already said it worked, but just double check!)
3. Test the circuit in the car up to the relay. To do this, turn ignition on and press the horn switch. Relay click? then good, the circuit in the car is OK. Relay not click? Could be a faulty relay or a faulty switch. To test, remove relay and put a voltmeter between the terminals that I think are labelled 85 and 86 on the relay and see if you get a good 12-13v when the switch is pressed.
Yes, then it's probably the relay at fault. No and it's probably the steering wheel switch or an earthing problem with the steering collumn. Test the earth on the steering collumn by checking the voltage between the metal part of the steering collumn and a +ve source such as the cigarette lighter (carefully!)
4. Relay click, but still no horn?? In this case, check the voltage at the horn while the switch is pressed. Anything much different to your voltage across the battery, and there's probably not enough to sound the horn (they need quite a lot of power) This could be the relay again (corroded or worn terminals inside or a faulty relay) so try a new relay, they're quite cheap to buy. It could also be the wiring or fusebox. If there's no voltage at all, this could be the relay, wiring, fusebox or firstly check the fuse again if there's no voltage at all!
5. If you have a low voltage, then test for current loss in both the +ve and the -ve circuit. For the +ve, check the voltage between the +ve feed on the horn and the battery earth while the ignition is on (they are switched by earth, the +ve is live all the time the ignition is on) any thing much different to the reading across the battery, and you're loosing current flow via the+ve side of the circuit (due to corrosion or degradion in the wiring or fusebox componants most probably.)
6. Test the earth by taking a reading between the earth wire for the horn and the battery +ve (while the switch is pressed and ignition on-so the relay is active!) and compare this to the reading across the battery. Anything much different. and you're loosing power in the -ve circuit (due to degraded wiring, fusebox componants, earthing point or the relay possibly.) If you're getting good readings voltage wise, but it's still not working, then it might be a matter of ampage as oppose to voltage, (although voltage is a good indicator if there is a problem, high ampage is more of a stress, and some circuits only show up their problems under stress)
At this point, I'd be looking at the voltage and ampage at the horn end of the circuit while the horn is connected and being sounded, but hopefully by this point you'll have a working horn.
Mike.
1983 White cabriolet GTi
There's no continuity to earth from the steering wheel but when a temporary earth is made the horn works fine.
I've not got a horn either but someone has previously bypassed it with a naff switch on the dash!
Will look into mine this weekend too - thanks for all the info guys!
1990 MX5 Mazda
2003 VW Passat 130 Sport
Sylva Fury 'blade powered…
I've tested the horn connected directly to battery- ok
I've tested the relay by connecting it to the battery- ok (clicks as it should)
There is NO click from the relay when the horn is pressed on the steering wheel
Put multimeter across pins 85 and 86 in fuse board and 0v when horn is pressed
(Def the issue)
Checked steering wheel earth by measuring V between +'ve from cig lighter and steering wheel column, got a steady 12v
So, guess I'm looking for whatever 'feeds' pins 85 and 86 of fuse board and then trace back to find fault?
Looks like someone has been here before also, the wiring is a bit of a mess
Gonna take passenger seat out so I can fit in the foot well, been yoga posing to examine the wiring so far and its killing me
Wish me luck
Re: Help, I've NOT Got The Horn
Ok, gonna kick myself square in the nuts later for thisdavidturner01 said
Afternoon all, digging up this ancient thread as I've got a similar issue.
(Def the issue)
Wish me luck
Turns out when I replaced the steering wheel I hadnt checked the brass ring had good contact with the small brass contact arm coming from the steering column
After very nearly tearing apart my electrics and fuse panel I noticed there was a gap
Bent the plate up a bit so it it was in constant contact with the back of the steering wheel, horn worked
Dont tell my Wife!!!
Hope this helps someone
