Fuel pump relay
(In Topic #156481)
Fuel pump relay keeps shutting off. Its a 7 pin one, Relay numbered 3.
I replaced this relay with just a normal one with only 4 pins and that solved it shutting off. So know that it is the standard part of the loom making it shut off. One of the 3 extra pins on the fuel pump relay to be specific. From the diagram it looks like these pins go into a transistor to shut the relay off. But what are these pins getting signal from?
Is it a crude rev limiter for the old engine? To cut the fuel when it got to a certain RPM? And now because it has no signal its confused? It was a GTI.
Any ideas?
Mk1 Golf Gti Abf conversion Project
Mk2 Golf Gti 16v
Mini Cooper S R53 (Daily)
