Blower working intermittently
(In Topic #102792)
Sometimes it works, just about… other times it doesn't at all.
Sometimes it works when turning left too :dontknow:
Theres plenty of heat, so even with the blower not working the car still gets warm etc.
Does this sound like the blower needs replacing?
Is there anything else I should check before ordering a new one?
I took the scuttle off over the weekend and cleared out the leaves (there weren't many) and checked the wiring which all seemed to be intact. I'm still to get the multimeter on it.
Web Team
worth a try, :dontknow:
it doesn't cost anything & only takes a few minutes
fingers crossed best case rather than worst case.
I've also ordered a new switch from GSF as it was cheap enough to try.
I tried the multimetre last night and found there seems to be no power getting to the blower.
I've not yet checked to see if the blower fuse is getting power. Just about to do that.
On a possibly connected note though, my heated rear window doesn't work.
Do the blower and the heated rear window share a ground point?
That should tell me if the two issues are connected.
Blower has now completly given up, doesn't work at all.
I doubled checked that it was getting power and it is, a full 12 volts. Maybe I didn't have the ignition on the last time I checked… :dontknow:
Either way I changed the switch which hasn't fixed it, so can only now assume that it's the blower that needs replacing.
The heated rear window seems to be down to a dodgy switch though. So should have that fixed by the weekend with a new switch on it's way 8)
blower fault
Re: blower fault
Thanks Scouse, do you mean the leaf guard, or the large plastic surround around the blower and heater matrix?scouse said
blower fault worn bushes . if you lift your bonnet. take of the plastic surround of the blower
Are the bushes available seperately?scouse said
you will see in the middle a small piece of copper wire follow that and that were your bushes are replace them
Can I get them from somewhere like GSF?
bushes
