12v feed needed from fusebox where ?? (g60 wiring loom)
(In Topic #163490)
it needs to have 12v while cranking so as not to interupt the ecu for the g60
i think ive got most of the other wires done to where they should be but seen a few comments when looking around about the live feed for the ecu
and getting a power spike and damaging the ecu any help greatly appreciated
thanks matt
jammie dodgers rule
30 - live
85/31 - earth
86 - ignition live from d2 or d7
87 - output to ecu
the later G60 use a #30 ecu relay, if so then get one from VW then wire it as above and in addition pin 86a goes to the G60 ecu pin 23
jammie dodgers rule
