Rear disc conversion brake lines - input/opinion.
(In Topic #233104)
I am looking for thoughts on the brake line positioning
Thanks am using the flexi hose holders from the mk2 + mk4 callipers. The hoses I purchased ideally would have been a little shorter however I am where I am on that.
Have mounted the wheel on the axle to check clearances and it's ok but a little tight for the solid line.
This is where I need your input/experience - does it look alright to you guys or is it a bit sketchy by the wheel edge?
Just seeing if I am being too maverick or cautious here.
If anyone has a similar set up photos would be helpful.
Thanks Craig
I would also isolate the copper pipe from the axle by using rubber grommets split and slipped over the lines, or rubber strips and tie-wrap it to the axle with stainless steel wire-ties, as I know this is mocking up, but consideration of anti-rubbing and chattering should be considered to prevent the lines from repositioning themselves and or chaffing and eventually holeing themselves or work maring your pretty looking axle.
Lines are copper plated steel so I should be ok on that one - more luck than judgement though.
Thanks need copper slip is at the ready for when I do the tightening up.
Insulated to bracket with some fuel hose slipped over the line before making off the ends so nicely secured and my rear axle is electro powered coated so pretty well insulated for galvanic corrosion.
Stainless ties is a great shout and I shall invest in them.
Any thoughts on the route near the wheel? I think with the ties you suggest I will be happier with it as it will be more stable and not possibly move into an area where it can rub.
As you can see the gap is a finger size so ok but not exactly spacious.
Just looked at the wheel arch and may need to do it a little more direct. Also need to consider not stressing the union so the bends help with that.
Does any of that make sense?
J
It's spring steel so rock hard but should bend with a little heat.
Cheers for the input on it always the vision I needed. Will post once done. 👍
Firstly it’s not cheap. Allow about 750 to 1000 to get it done to the standard I have, which I consider good for a novice and built to last. If you don’t refurbish the rear axle then maybe you could do it for 500.
Anyhow. I am now happy with the line location just need to do the other side but Harlequins are playing Sale tonight so it’s a tomorrow job.
Some photos of the pipe run with both ends made off.
If you want to see me wrestle this and the new fuel tank in then pop over to the other thread.
Thanks to those that helped me out and get my peanut brain around this one.
Personally, if I bought your car, one of the first things I would do is change out that flexi for a hard line.
Flexi's are necessary where there is axle movement for obvious reasons, but they are the weakest link, especially the braided ones, because you are unable to see any signs of perishing or cracking on those.
If you hard line it I don’t see how you can service the rear brakes
In that case, they’re a bit long, but good job!
So how have you uprated the front brakes so that you still get a 60/40 front bias, and load proportioning?
However as mine is no longer lowered and I leaving standard brakes on the front (for now) as it’s more for modernising and general improvement as my power is a pretty standard 1.6 then I should be ok is the general feedback
I have g60 servo and m/s to fit and in the engine bay are some in line valves on what I think is the rear brake lines. I will also re-connect the loading bias valve on the rear beam.
Once done I will need to do some hard stops and make sure I don’t lose the back end - if I do then it will be adding some in line reducing valves on each side to reduce the pressure. Apparently it only impacts the emergency stop style braking or hard driving etc. So for testing it should be fine I won’t suddenly find myself facing the wrong way (hopefully).
Agree the hoses are a little long but I ordered them as MK4 to MK1 conversion hoses and they can like that. At almost £50 I am working with what I have
Next mission is the servo. Had a quick look yesterday and could be interesting getting that thing out. Just ordered the correct spanner’s as fittings all very tight and once the lines are disconnected then I may see a little more what I am dealing with. I sense a new thread coming on asking for lots of help and advice again. There are two switches on the current m/S which I do not know what they do plus a little aluminium block which splits some flow. Once again need to work out where why and whether still needed.
Simple job apparently but there are some bits still that make my brain ache.
It would be good to find the definitive brake upgrade though wouldn't it?
And the other consideration is insurance cover - "I've modified the brakes" is not what the insurance companies like to hear !!! Might be wise to get an engineers report once it's done.
Good luck with it tho' 👍🏽
