instrument cluster
Hi All... Does anyone know if the 1983 GTi MK1 instrument cluster is the same as the early MK2?
It's the same shape and will physically fit, though I think there are some differences. Speedo's read different on some 120MPH vs 140MPH for example.
instrument cluster
Mount points are totally different, and it may have the single or dual loom connectors I have a 16V Mk2 one fitted in my mk1, I grafted the mk1 mounts on to the mk2 unit and wired the dual connectors into the mk1 loom. Everything works including the MFA, I did use early mk2 stalks with the MFA switch as well
Cheers,
Ade
aye as lhasa says, they dont fit or plug straight in some mods and wire splicing is required
