Engine Identity in '93 Golf Conv??
(In Topic #235508)
EZ or EX??
1. V5 and Boot sticker says it's an "EX" prefix engine - 1800 - which I believe would be the correct one? However the engine block has an "EZ" prefix which I believe to be a 1600. Having now removed the head and measured the Bore and Stroke (81 x 77) I think I can confirm this. However the head has a clear Pt No of 026 103 373Q which I think I have read is for an 1800 unit. Given the the bore is the same on both engines I guess the head is interchangeable? Can anyone throw any light on this? Hard to understand why someone would replace an engine with a smaller unit??
2. Assuming it is an EZ/1600 which Carburettor should I have? How do I identify the one I have got?? It's definitely a Pierburg ..
3. Which car would an "EZ" engine have been fitted to? I ask because it would be nice to track down a workshop manual that applies to the engine. Niceties such as timing marks etc are still a mystery.
4. How can I identify whether "my" head has hydraulic tappets?
Thanks in anticipation!
https://vwgolfmk1.org.uk/forum/index.php?page=topicview&id=helllllpppp%2Fhydraulic-tappets-or
Can you post up a picture of the engine?
EZ engine are from a Mk2 Golf, 1988 to 1991
The timing marks etc will be the same as they are the same engines.
Have you checked the stamped in engine code as it could be dirt covering the X and making it look like a Z, a wet cloth can sometimes help?
1.6 heads have the main water outlet going to the radiator between cylinder 1 and 2.
1.8 heads have the main water outlet between cylinders 3 and 4.
Either head will fit a 1.8 engine block or 1.6 engine block.
There is sometimes a 1.8 or 1.6 cast into the back of the engine block so check there as well.
1988 Mk1 Golf GTi Cabriolet 1.8cc DX, K-jet. Daily drive. 300,000 miles and counting
Be wary of 1.6 or 1.8 casting marks as the same blcok was used for both so can be misleading
The 1.6EZ was prob the easiest engine to find if the original Cabrio one had died and needed replacing
I attach pics 1. The engine prior to stripdown 2. From today of the cam area. 3 the engine No
Looking at the link from mark1gls it seems I do have an 1.6 EZ with hydraulic tappets.
Any ideas on the carb I should have?
Peter
….and if I'm doing that maybe even an 1800 injection unit or a 2 litre?
Watch this space…..
Once again thanks for your help. And I thought Beetles were complicated!
P
