Brake lines replacement
Hi
Where can I buy the brakes lines which run the length of the car please. There ok for now but will need changing soon I'm sure. Mk1 golf cabriolet
Sent from my Pixel 8 using Tapatalk
Pretty sure they are fuel lines, not brake lines. Have a look at https://www.classic-vw.co.uk/fuel-pumps--pipes-354-c.asp
Yep those are your fuel lines.
Is it injection or carb? If it's carb you could do what I've recently done and get some 8mm internal diameter (I.D.) copper pipe, easily bent to shape by hand. The only thing is you will need a bead roller to shape the ends to accept the rubber hoses
https://www.ebay.co.uk/itm/333832762101
