WILL PORSCHE SEATS FIT?
(In Topic #79118)
Need a new front seats for my 82 GTI. Does anyone know if a 1973 on Beetle seat base is the same as the MK1. The fitment looks the same & if it is I can get some Beetle universal subframes. I'm looking at 944 or 911 seats. If there are any other suggestions on how they will fit it will be much appreciated.
your other option if you're up for a little welding/fabrication is to mod some mk1, mk2, corrado or scirocco (the last two sit lower than the golf ones) frames by cutting and rewelding etc. to make them fit
I actually started this once, and it went fairly easily, I started off with a knackered mk1 seat, chopped the frame about abit and had it trial fitted - it sat quite a bit too high, so I though I'd try some corrado seats (I could probably have just kept cutting/modding the mk1 frame but….) so picked up some water damaged ones from a scrappy I chucked them in the car to see how they fitted and they kinda stayed there!
anyway I don't reckon it'll be too hard if you've got access to an angle grinder and a welder :wink: 8)
good luck let us know how you get on
black 5 door mk1 GTD
mk1 scirocco Gli in bits
