where can i get a shell chemical dipped?
(In Topic #90677)
if anyone knows anywhere please let me know
thanks. rob
Speeding is like masturbation, everyone does it ,but it's not something you should record and put on the internet!!
there in preston, dnt know much about them just got num from a show
very friendly and open to a little negotiation on price!!!!!!! :roll:
?10K down - almost gave in! 95% done!!!!!
Did a brilliant job.
One piece of advice:
If they ask if you want a receipt, you know what to say!
I've got good directions/map to their premises if anyone needs them
KDXdestroyer said
SPL (surface processing ltd) did my Mk1, pretty good turnaround - ask matt and he'll walk your through the process..8O
Did you have your whole shell done, and how much did they charge you, if you don't mind me asking?
Rich
its a scary sum of money and dont underestimate the amoutn of time it takes to build up the underseal, seam sealant and insulation that is on these shells, it takes for ever and it isnt cheap.
Whatever you do - dont skimp and have it just primed - it will quickly resemble a tea bag - they do the Pro drive works subaru rally cars - they reckon that after about 18 months they have some serious rust on them..
AFTER DIPPING (red areas are bits i had subsequently repaired)
arnt you impressed in the way the dippers have added the rust and naff green paint?
SPL experience
Definately worth a look!
Alfie
Wanted: Front Bumper, DESPERATELY NEED A DRIVERS WING!
MY Build Thread
My Facebook Build Page #Project83
Shell dipping
Is the second photo AFTER the car has been at SPL? If so did it have the e-coating they provide? to me it doen't look as though it has been dipped??
the red primer spraying is simply areas that i've had work done on AFER it was dipped, as you always get suprises when ALL the filler goes…
as fortheir work - 100% mine was sat for about 6 months before i had it painted - only 1 tiny area had a spot of corrosion which i have dealt with.
i rate them highly and dont regret having it done at all!
