Restoring the clock display
(In Topic #72665)
If you decide to yours be very careful with cleaning the needles, clean them very gently.
Out of interest, what is silvo wadding if not a silly question?
You can buy a tin of it from most hardware shops for about 3 pounds. Looks like cotton wool. A watch maker told me he uses the wadding to remove scratches from the plastic face, so I thouht I would try it out on the clear plastic on the display
Duraglit and brasso will probably do the job just as well. Best to just use a tiny bit of the stuff and just wipe it over a couple of times then get a tissue and keep rubbing the area until all the smear from the silvo has gone.
I'd suggest you use with care though, its not very abraisive at all but I wouldnt like someone to wreck something using this advise.
Cheers,
Ross
My speedo is still playing up and I need to replace a few bulbs in there too as well as clean the clear plastic. Might do this on a spare set and then swap it out…..
Cheers,
Chris
I need to do it again to get the MFA fully working
This would be a good time to take the clocks out again and give them a good check and clean up. I still have the original Motometer clocks in there but the speedo has never worked correctly since I got the car and also the bulbs need replacing in there too.
Car is off the road anyway until the fuelling issues are sorted, so maybe now would be a good time to sort this stuff out.
Cheers,
Chris
I then put the speedo from my VDO set (with the original mileage on!) into the Motometer instrument pod. All works fine now except only clock and oil temp work on MFA. I was planning to sort this on weekend. I was told in here before that the screw in widget thing on the back of the speedo (small black plastic thing with three (?) metal prongs on and two screws to secure) needs to be swapped for the one off of the Motometer clock set.
Gonna put some 2W dash bulbs in too! thought I had done but checked on the weekend after seeing lhasas post about em and they are only a dim 1.2W!!
Anyone know if you can safely replace bulbs in the heater panel and ciggy lighter with 2W ones as well?
New Member
Can anyone help with ideas on sealing the rear screen on my coco cab, absolute bitch I can tell you Ive tried new rubber seal new glass and pumping it full of windscreen sealant you know the black sticky gunge you spend the rest of your life trying to get off hands clothes paint hood and anything else that has come within 10m of it. Thanks Paul
Cant help with the window i'm affraid - would have suggest the 'black sticky stuff!!'
Thanks Hairyarse
I shall keep reading the forums and hopefully be able to pass on some helpfull advice. LONG LIVE THE MK1
At least you wont make the same mistake again! :wink:
Re: Thanks Hairyarse
pmw100 said
Why o why didnt I join this owners club years ago.
Errrm, it only started up in November 2004
1983 White cabriolet GTi
