Getting rid of a sunroof
(In Topic #83411)
My car's got an aftermarket sunroof that doesn't work and has been bodged shut. I bought it because everything else about it was spot on, but I can't live with this sunroof and don't want a replacement. Has anyone tried repairing a hole? and can you get them 100% again?
Mk2 VR6, G60 CABBY
Best bet is to get hold of a non sunroof roof and cut a patch to weld the hole up. A decent body shop should be able to do that for you…
Alternative is to replace the entire roof panel.
How much is a roof?
Baz
Get to a breakers and find out...
Roofs are easy to get hold of but welding up the hole is a different matter,if you jst want to fill the area you will get loads of distortion on the roof when you weld it up and lots of ripples everywhere,you need to replace a bigger section or the whole roof to avoid it i`m afraid.
keep on keeping on
Try Crazyquiff - he's got a non-sunroof roof in stock I'm sure
HTH
Rich
HTH
Rich
A friend of mine, who used to have a body shop, filled the hole on the a volvo and you couldn't tell, he didn't weld it in due to destortion. he used an epoxy glue for metal (Something he got from the paint supplier) and you couldn't tell.
Go see a decent body shop they should be able to help.
Rob
Rob
Audi A4 1.9TDI - Gone
i would definately like to find out some more info on the epoxy glue for metal.
im not going to the extreme of getting rid of the sunroof completely but ive got a rusty patch next to the sunroof of about 1 inch square which im worried about, it hasnt holed yet but im planning a mini resto in the new year.
if this epoxy stuff is the business then it could be the answer to my problems!!
if anyone finds any info then pls post it.
ta!!
John
John
1983 mk1 gti 2.0l 2e powered
newman cam
ported, polished, big valve 1.8 head
audi throttle body
SWWWWEEEEEETTTTTTTT
newman cam
audi throttle body
SWWWWEEEEEETTTTTTTT
i just bought a non-sunroof roof. 45quid. cut it off the car at the bottom of the a.b,c pillars. they can do it at the style haus
Got a non sunroof today myself. 350 quid though. Think I'm going to keep it though put my g60 in it and use the other for track days or sell it. I'll have to see what's behind the bodykit when that comes off.
Mk2 VR6, G60 CABBY
