Starting issues, k jet settings possible?
(In Topic #155273)
Website Manager
See the little screw head in the center of the diagram on the arm connected to the control plunger - turning that determines how much fuel flows to the injectors for a given of airflow - so you can get it as bad as fuel flowing for no air !!
As rubjohnny says it is trial and error - you could try removing the boot and manually lifting the flap and trying to start as this might give you a better idea as to how far out the control plunger is.
