ported head
(In Topic #121413)
ported head
Basically the answer is, you can quite easily lose power by porting if done incorrectly so make sure you get it done by someone that has a few good ones under their belt!
What you DONT want to do is polish the inlet ports. If these are too smooth there is not enough turbulence in the air to allow proper atomization of the fuel, causing it to settle on the port walls, not good. Thats why when you buy a gas flowed head from TSR or the like the inlet ports are left slightly rough.
Bigger isnt necessarily better, trust me.
Big ports flow a lot of air, but you need a big valve to match and a cam thats matched otherwise youll not derive the full benefits.
Having said that, big ports on a road engine arent any good for normal driving because the port may be bigger but it also flows slower which hampers cylinder filling at lower valve lifts.
In other words its better to have a fast flowing port than a slower flowing port.
The exhaust ports on these heads will flow more with work, but the big issue with them is the exhaust valve size and possibly shape.
Ive found on multiple occasions that the flow of the ports can be improved somewhat on the exhaust yet once the valve goes back in and the ports are tested with the valve being lifted at 1 mm increments to mimic the cam opening it, the increase isnt as dramatic.
The big gain on the exhaust port comes from a bigger valve but the flow ratios of exhaust to intake need to be retained if at all possible so that you dont have a situation whereby the intake underflows.
This possibly explains your heads lack of any work on the exhaust side, but its not really professional to do only one side as gains are gains even if they are only small.
How much do your ports flow? Who can tell until its tested?
Heres an example of what im talking about.
I recently tested a big valve audi head (same basic head as the 8 valver plus 1 cylinder extra) whilst at the same time porting another stock sized valve audi head.
Heres what i found.
Exhaust ports.
Lower plot is the stock exhaust and stock valve.
Middle plot is the modified exhaust port and the stock valve.
Top plot is the big valve in the exhaust.
As you can see, it flows a lot better than the stock or even modified exhaust port, however, take a look at the intakes for the same heads.
Blue trace is the stock intake port.
Green is the big valve head.
Read is the modified "stock" port.
This big valve head makes more flow than the stock port at all points.
However the modified port with the stock valve size only loses out right at the top of the cam lift where the valve spends only a fraction of its time.
Its making more flow and stays right with the big valve head almost all the way to the top of its lift, so although this particular big valve head is an improvement over the stock port its very definitely not an improvement over a modified port and stock valve in this case, but its probable that i could have made the big valve head flow better still as it came to me done by someone else- (no idea where it originated).
If you were wondering what such a modified port stock looks like btw, heres a photo of mine that i did.
Intake.
Exhaust port.
That finish you can see on the ports i did is about right as its generated with 80 grit carborundum tapes and is smooth but very definitely has a rough feel to it compared to one finished finer at say 120 grit which is what i use in the exhausts…it helps on the exhaust to keep them from choking up with carbon.
The casting mark cleanup actually does in some cases yield quite a good increase by itself and some of the heads ive done from different years were dire in that respect with lumps of flash sticking out and ridges right where you dont want them.
Anyway apologies for hijacking the thread, ill buzz off now and leave it free for others to chip in!
