best way to take the engine out????????
(In Topic #74544)
gotta tek mine out soon so would like to know the easist way?
also any tips would be nice!!!!!!
Craig
Is there anything to be wary of, or is it just a case of disconnecting everything and lifting it? I was planning to lift it using a hole on the transmission, together with a chain or rope around the alternator bracket. Or are there better places to lift it from?
I did think about tilting it and lifting it out but it seemed like a lot of work so opted for the other way in the end. I also thought it wasn't as far for the engine to fall if you did happen to have a mishap!
MK1 GTI Campaign
MK2 GTI 8v
Imitation Magic Tree - 'Black Ice' smell
Plenty of rust
Embarrasing fuel problem
Porous cooling system!
MK2 GTI 8v
Plenty of rust
I have no worries that my crane will lift the car. Its a 2 ton model, and its very long reach as well as high lifting!
yes disonnect the driveshafts from the hubs mate :wink:
yo have to raise the car up a fair old bit though :cry:
I disconnected the driveshafts at the hub end too.
Only problem I encountered was getting to the engine mount nearest the bulkhead really low down. I wondered why the engine wasn't moving when I started letting it down and then realised there was another engine mount to undo :? I'm struggling with that one again this time as it's pretty rusted.
MK1 GTI Campaign
MK2 GTI 8v
Plenty of rust
MK2 GTI 8v
Plenty of rust
I have used an engine crane to lift the front end of a sierra once the engine was dropped.
Most cranes will be fine liftign a car shell at one end without the engine.
TT
I might try the 'underneath' technique, getting the whole lot back in.
I would have taken more pics as it came out, except the camera had a flat battery!
All I need to do is change the clutch. If I'd known how tight a fit it was, lifting the engine/transmission up, I'd have left it in place and simply dropped the left hand side down, then had a go at sliding off the transmission. In fact, I might put the engine back in (once split), then do this, as it was a bit too awkward (space/clearance) with both together.
The Haynes manual is a bit useless because its info on changing a clutch, merely says to remove the transmission.
In retrospect, I could have kept a lot of stuff connected, taken the 3 mounts out, and tilted the whole lot downwards. But at least I know how to take the engine out, now. And the only parts to replace are a couple of copper washers where I disconnected the fuel lines. I kept the coolant!
sneak said
To be honest doing the clutch on these is abit of a pain, as you have to take three, out of four of the engine bay mounts out anyway. You were probably better off taking the lump out. You may want to change the engine mount next to the cambelt as I found mine was split.
The front engine mount looks very wobbly - is this normal? All other mounts seem fine. I'll have a good poke around the engine bay, though, for example I know its worth changing the steering rack gaiters (if worn) now!
Life Member
- you could probably leave the downpipe on and its easier to break the exhaust line here rather than up at the manifold
- easier to leave driveshafts on disconnecting at the hubs
- no tilting of the engine and messing around with the left gearbox mount
- probably leave rad in
- probably leave bonnet on using a crane to lower engine to the ground
- less risk of damaging other parts or your paint
- its the way VW put them in on the production line (along with the complete struts/hubs/brakes) so it must be the easiest
I tried to take it from the bottom but could not safely get it high enough. If you can rope in a couple of friends I think 3 men could easily lift the car from the front bumper over the engine and back.
Anyone lifted the car over - is it a 2 or 3 men job?
A tip is to use old seatbelts for lifting as a good alternative to rope/chain.
Rajan
sneak said
If you mean the front one by the starter motor this sould not woble as it is a solid mount. If Iwas you I would change all the mounts as most likely they wil all be shot. May seem like alot of work but it will be worth it.
Mine's in 2 pieces, is this right?
Historically, the car was a 1600 but is now an 1800, I think the mounts have been changed at some point in its life and all seem ok.
Looking back, I think its better to take it out the bottom than the top! But I'd have to have a think about how it can all be done with 2 axle stands, 1 trolley jack and 1 engine crane. My concern is, you'd use the crane to lower the engine, then rest it on the ground, then use the crane to lift the car (bumper off, to use the towing loop?) but you'd inadvertently swing the car around and knock the engine over! Also, once its up, the engine would be between the legs of the crane. Xmas 2006 list: 4 poster lift!
