mifire
(In Topic #132429)
mifire
only running on 2cylinders i need to double check that it's sparking on all 4 when i go back to the back later on got the timing on the dizzy set up by the chissel cut in the fly wheel and the engine timed up with the punch mark im wondering if the cam timing is out by a tooth or so it does line up up with the rocker cover edge or is it the cylinder head edge it lines up with? as i have it lined up with the rocker cover edge :roll: which is where it show's you on autodata but auto data isnt the best for info sometimes
