EZ 1.6 Ignition timing setup...
(In Topic #222751)
Timing help
Just after a bit of info.. Going to do the ignition timing on my 1.6 EZ engine (carb)
I've found out via forums & haynes that its to be set between 17-19deg BTDC ..
That part is fine BUT.. Is this with the Vac adv hose ON or OFF and plugged up???
Haynes says..
1.6 litre (code RF) - TCI-H . . 17 to 19° BTDC at 700 to 800 rpm, with vacuum hose disconnected
I know this is a RF code engine so my question is vac hose ON or OFF for a 1.6 EZ?????????
