1.5 gl and weber 32/34 dmtl, can it be done
(In Topic #144912)
My car is a 1.5 carb with manual choke, manual gearbox. i put a pic up and the carb has been identified as a 32/34 dmtl.
whats the cheapest and easiest way to fit this to my car?
where will i get new jets from and which ones do i need?
sorry for the noob questions but i really dont have a clue with this stuff.
i have tried the search but only get results for 1.3 and 1.6/8, is this a sign that this carbs not a good idea for my car :dontknow:
thanks in advance.
off to update my build thread now 8)
http://www.fastroadcars.co.uk/shop/index.php?act=viewProd&productId=214
can get the jets from the same place..
cheapest and easiest way to fit would be outside your house, easy job if you have a socket set
Take it easy ; )
what size jets do i need?
isnt there also a way of using a 1.6 inlet?
you could put a 1.6 manifold on if you have one - fiddly to do with the head in place though..
Take it easy ; )
G60
thanks
Greg
mwalker
big_nick said
the direct replacement carb for your 1.5 engine is a Weber 36TLP but you can make the 32/34 DTML fit with an adaptor plate, listed here
i just looked at this adapter plate and its 'two bolts' to connect to the manifold. but they have 3 bolts that secure the carburettor down? very confused :/
i need to do this conversion badly
I was told by someone at Fast Road Cars that the adaptor plate won't fit due to the bolt pattern.
Has anyone tried the method using a MK2 inlet manifold? I'm tempted too but unsure which manifold it is I need.
Had a weber 35 tlp that's gone bad so changing over to 32/34
