Shellby - 83 gti ABF on carbs
borednow said
Bad news on the engine mate. Silly question but has it got oil in it? If not add some and let it soak and you may be lucky and it might free up.  :(
On the plus side though the state of your garage made me laugh 'cos I thought mine was untidy  :thumbs:
Thanks for the tip :thumbs:
I drained the oil, but everything is still coated on oil, not dry, just feels "tight" when you rotate the crankshaft :(
It's not a garage, it's a barn, I'm only there once a week, and stuff keeps getting moved around when I'm not around :P    But at £25 a month I can't moan :thumbs:  :lol:
engine sorted and turning nicely   :)   seems some idiot (me) put the big shells back on the wrong way round  :P . turned them 180 degress and everything is good again  :lol:
Still awaiting engine bearings and paint, so very slow progress at the moment  :'(managed a few tiny steps forward
first my loom arrive from Rubjonny (cheers john  :thumbs:)
no idea what to do with any of this  :lol:modified the dash mounts
and trail fiited the s1 dash, went in very easy  :)
then tried the clocks
these dont seem to line up with the mounts on the dash   O_o Do i need different clocks? perhaps the black ones?  :Pdont want the fusebox in the standard position, so made and fitted a little mounting bracket
engine bearings have arrived, so hopefully sort the engine next week and trail fit it, that will be a welcome step forward  :)thats it for now. any help with the clocks would be greatly apprieciated.
matt
Last edit: by pazwaa
If you move the fusebox there my looms probably wont reach :(
dash and rear ones probably ok, but the engien one may be tricky even if you put grommet holes in the middle. lighting loom will probably be the bigger problem tho i recon, most of the engine loom will prob be ok with a hole in the middle but lighting loom prob need a fair bit of faffing
Thanks for the heads up john. Will be doing a tucked loom installation, so knew Id have to play around with it  :thumbs:  first I need to understand how the wiring works, cause all your descriptions still make my head spin  :lol:
Any idea about the clocks not fitting?
sorry not clued up on the S1 stuff really :(
Nice work Matt. Not sure why the clocks wouldn't fit, they're S1 clocks and S1 dash. I don't know enough about how they go together sadly though to help
No worries andy, cheers anyway  :thumbs:
Bit of a mystery, like you say, should fit  O_o
Painful progress - spent 2 hours fitting the boot lock and getting the boot to latch  :P Couldn't get the lock to engage, had to keep enlarging the holes in the shell. got it done eventually.
on a good note, thats the last of the panels lined up
blasted all the debris out. so should be all in grey primer by the end of the month  :lol:
2 hours - bet you enjoyed that!  :lol:
Yep, open hole out, try lock, fail, open hole out, try lock, fail….  O_o
last photo of the old girl looking old….
myself and the painter are on holiday next week, then the week after she will be in grey primer - all one colour finally  :lol:on a different subject, a new toy has arrived
1961 series 2 lambretta LI. something for me to restore whilst at home  :)
Does the missus know you're going away with the painter Matt??  :lol:
Will be good to see colour on it. Nice new toy too  :thumbs:
In hindsight, maybe I should have worded that differently  :lol:
Cheers Andy. That's the eBay photo, real thing arrives tomorrow, rather excited  :thumbs:
Can't wait to see her in primer Matt. Loving the Lambretta  as well mate, very nice :wub:
Thanks Andy, all one colour is gonna feel like a massive step toward, finally  :thumbs:
How's your painting progressing?
Shouldn't be too much longer now hopefully, I'm off back down there at the weekend to check it out :thumbs:
small update
Shellby awaiting paint, looking unloved  :(
3 week delay on the next coat of paint  :'(
so on to the engine, and fitting new bearings. been putting this off for a while as i was nervous about taking parts out of the engine, but it went well  :)
all parts removed and bagged/labelled individually
camshaft out
told myself "dont drop anything in the engine". i didnt listen, you can just see the rouge, dropped nut  :P
mr magnet solved that
 :lol:
new main and shell bearings fitted
camshaft back in
nipped the nuts up, check rotation, all spun nicely, phew. so torque it all up properly, checked rotation again, all good. so sump back on and finished
next step, build the engine up and add gearbox  :thumbs:
Hi fella, build looking good.
It's all shits and giggles until someone giggles and shits
I've moved my photos to a different album in photobucket and the links have been broken  :banghead:
Can I re-link them anyone?
Matt
