Project "little monster"
(In Topic #89175)
The new arrival. Full MoT too….
It won't be seeing the roads for a little while yet though.
Hello? What's this? Hmmmm, it has those funny oval headlamps, that means it must be a Mk3. An uprated 2 litre? ABF engine perhaps (2litre tall block 16V)? Didn't they do a more powerful one with….
WARNING - PURISTS LOOK AWAY*
(*in fact, you may as well forget this entire thread)
Count them induction tubes….1 2 3 4 …… 5 ……. 6!!! Cylinders! Yes, this is a common-or-garden, just had a slight accident resulting in a Cat C write-off, VR6!!!!
Here's another pic, showing the main area of damage. The airbox and rad are trashed, but the chassis legs, engine and alternator all made it unscathed. Phew!
Watch this space……
bet you cant guess what ecu will run this puppy and as far as im aware its not been done in this country yet 8)
so what kind of diet will this be on then
Web Team
ew said
So, you restoring a mk3 then:wink:
Looking forward to this one, get stuck in!
lmfao best of britsh
Unless that would spoil your fun of course
you owe me 1
:wink:
Basil Daham, 1995 VW Golf VR6 - www.MSruns.com read only forum (Jan.15,2018)
Here's the latest pic.
Cheers for the link Ben, I'd found that a while ago and it means I can simply go ahead with the Megasquirt in there!
Undoing CV joints, a bit of a pain/time consuming
Taking the strain
With the weight of the engine off it, the front crossmember can be unbolted and move out the way.
Then the engine can be lowered and slid forwards a little
Bit further
Clear of the car now
Better out than in
Tomorrow and onwards I'll be stripping what I need of the fuel system, the lambda probe, and a lot of the electrics (including the dashboard) and measuring and cutting the main subframe for the rear engine/transmission mounts.
VR6 caddy http://vwcaddyforum.com/showthread.php?t=492
VR6 turbo caddy http://vwcaddyforum.com/showthread.php?t=10536&highlight=turbo
1983 Mk1 Gti 1800
top thread paul, good luck with it
Chris
Need your console repaired or mods done? drop me a pm
front or back!!
god that should be good for 750 bhp for a grand eh!! :wink:
rebuild in progress....
perhaps it will be ready for the end of august
the pod is waiting :wink:
Is sir considering any forced induction? :mrgreen:
With a lack of space in the shed (long story), I've had to put this sheet over the engine/transmission and hope it doesn't leak or get blown away.
Best of luck…
Rich
