Project F
(In Topic #107310)
Project F
Hi all
I hail from SA Durban and these are some pics of the mk1 Fox im building for a track/road car .. it doesnt have MOT/COR yet so i am busy stripping it and doing what is still legal so i can pass it then comes the cage race seats etc
Please comment as i need as much help as i can get 8)
Cool, looks like you have made a good start!
Keep the pics coming!
Dibbler
Dibbler
That'll keep you busy :wink:
cheese and rice .. just spent a couple hours chipping off some of that sound deadening tar stuff … about 1/4 the way thru the floor
Thanks for the comments guys
keep thinking how cool it will be when im done
It takes time!
cool well my plans are to hit it at nites now .. ive just recently put down the cement under it and closed up the side so its kinda like a shack garage that i can work in without rain affecting it too much .. planning to cut the top of the firewall off .. trying to find out if its legal to do so tho
This is what im talking about .. abit expensive tho
Powerflex Black - Golf Mk1-REAR KIT
PB120VW
Price (INC vat): ?108.47 Quantity:
Product description:
Your question is "will they be too harsh". Answer: do you like cornering fast? - in our opinion essential for high performance applications. "Black" suspension bush kits. We supply Powerflex kits complete for front or rear suspension applications. Kits include all bushes required for front or rear application including anti-roll bar mounts and drop links. Damper bushes are not included in the kits due to the fact you may have new dampers or be considering buying them. In addition non-suspension bushes are not included - e.g engine or exhaust mounts. The improvement in response from one of these kits is superb, especially on cars >3yrs old. If you prefer all bushes are available individually - please email with your requirement.
The Black shore 95 bushes are around 35-45% stiffer than standard and are ideal for motorsport use. Unlike a Nylon bush enough compliance remains to make them safe and prevent damage to other suspension parts. Powerflex Black Bush kits bring: More secure on limit handling Minimum geometry change under extreme loads. Economy through longer life.
Powerflex Black Bushes made to order hence delivery time 3-7 days
PB120VW
sorry so long .. did some updates today .. nothing to hectic but something cool i think
ok so this weekend i found the Tig/Mig Welder in the garage and pulled the bad boy out to see what I could do ..
Now I need some help with the settings on the machine and Gas PLEASE .. because it was a balls up ..
Holes anyone ..
So i found the grinder and the spanners and operated those abit ..
removed the struts ..steering rack and grinded down some factory welds from things i had removed
inside
Outside .
So i need to learn to weld .. i dunno how the F to do it with this kinda machine .. It burnt the sharp point i kept making which i was told to do .. and it kinda welded the rod onto the point making it a ball .. and burnt holes in the car
Holes anyone ..
inside
Outside .
I only know mig but if you're burnign holes in the metal, either its thin and rusty or your amps are set too high - or both!
well i think its mig, please have a look at the first few pics and see if you can tell me what settings to try … also .. the little piece of wire that goes in the "gun" that you make the arc with ..do i need a sharp point and is it meant to stay sharp .. as i start it goes round
maybe its the wrong material .. its tungsten ? thanks so much 8)
Really don't know to be honest mate, only just starting to get to grips with MIG myself.
Try on some scrap steel with setting down low and just keep increasing until you get good penetration without burning holes.
Take a look here - Welding - The DIY Guide
I know it's only for MIG but may be helpful and show you what a perfect weld should look like! :wink:
thanks man will do 8)
ok guys sorry its been so long .. BTW I have found out that I had a TIG welder not a MIG and that is why I am battling so much and im told that its not meant for cars
anyway I have since removed the back axcel and petrol tank and today I cleaned up and repainted the wheel arch inners
Working on getting the stuff needed for Rear disc conversion and wondering about upgrading the fronts as well, dont want to change too much once I assemble if I can help it , hunting a FI petrol tank aswell
and planning on running a Beetle master cylinder … like this setup …
These are my pictures below from today ..
also got these 8)
and one of these
and one of these
