Mk1 4x4
(In Topic #154568)
Here is the shell, looking a little sorry for itself lol
The one big prob is it did have an aftermarket sunroof fitted till it flew up in the air 40ft when bringing it home
Here is the 4wd setup..
Now be very wary when buying stuff like this and do you research first!! I dint and paid the price…
First of all the prop is off a TT not a Rallye, the rear axle is off a passat, ya may think whats the differance well the mounting point is a differant size, bigger on the passat and a slightly differant angle.
They are slightly wider which would help with fitting the axle on as its very tight to fit on
The old mounting needed to be cut off, As you can see you have to make a jig on the axle so you can postion the conversion and Haldex dif up correctly.
Missing a pic here
Having a quick look to see how it will look.
Mounting point for the axle
The tunnel was cut out for the Rallye one to be fitted, the Rallye one has to be cut in half to shorten it, it will not fit at all..
Made a start on the front subframe.
New Boot Floor going in.
All i have time for as wife wants me outside Gardening
MK1 Golf 4x4 Build
MK1 Golf 4X4 | Facebook
Hope it all goes well mate for you. Best of luck
Shell is going to be fully blasted inside and out this year but just need to get the seam sealer and sound proffing off first >.<
Anyway, as the above pics ive got the boot floor in, just need to weld in a hump on the gap for the axle, the tunnel is half welded in and will be finished soon!
I have made some brackets for the axle mounting as you can see below, they still have to be welded on but they are in the correct postion..
MK1 Golf 4x4 Build
Audi TT Gearbox
Axle Inplace
Could not help myself to a quick fitment
still lots todo as ever…
MK1 Golf 4x4 Build
I am doing the 5 stud conversion..
2.5mm off either end of the shafts
Milled down to the lvl of the groove to allow the TT CV fitment
Hub needs 2mm off overall diameter
1 of the steps needed machining down
MK1 Golf 4x4 Build
Thought about a colour yet?
Marketing Manager
1973 BMW 3.0CS "Helga"
1981 VW Golf GTi "Agolf"
1986 Ford Escort RS Turbo S2
1987 BMW M535i - 'Klaus'
Instagram: @ahmet_e9
New mount point, rather large but will be putting a reinforcing bar to help with the load.
View not normally seen.
Started on the body work, getting a tad bored with the underside so thought it would make a nice change, im cutting as less as i possibly can…
Hubs fitted to the trailing arm..
MK1 Golf 4x4 Build
Vw golf 1980 cab (girlfriend's)
Vw T25 1.9dg auto hi-top autohomes camper
Alfasud 1.5ti green cloverleaf
Alfa 155 2.0 16v
Alfa 155 Q4 lhd 1 for 13 in uk
Alfa 155 2.5td lhd the only 1 in uk
Alfa 155 2.0 16v
Also have Toe and Camber adjustment for the rear wheels
MK1 Golf 4x4 Build
