mk1 1.8t conversion qpeng 20vt agu dims(Doin It My Self)
(In Topic #116218)
my daily at the start
under way first day get rid of the old
and what can i fill this hole with i wonder
poor golf not goin any where like that
new heart for the old boy
and up to 20/09/2009 this is where i am and awaiting qpeng diy ecu to arrive and a downpipe to cut up and make fit.
thanks
lewis
coolant pipes
vacuum pipes
grease and connect driveshafts properly (as only temp fitted at mo)
little more wiring then be there i think, but to be fair my profession i am a trainee pharmacist, and alot of this is pretty new to me, but best way to learn is to just av a go i believe. soif any one else can think of any thing i may of missed or need to do please please do let me know
thanks
lewis
lewisf89 said
….but to be fair my profession i am a trainee pharmacist, and alot of this is pretty new to me, ….
It's good that you'll have a ready supply of drugs for when things don't go quite to plan! :wink:
knock sensor 1
knock sensor 2
it all turning over now and electrics pretty much sorter just vacuum pipes
how did you go about the engine mounts?
?600 Engine and gearbox Delivered
?700 qpeng ecu
?50 fans
?20 air filter
?100 rear disc conversion parts
?100 wiring loom from a whole golf
?80 gear cable linkage
?80 intercooler pipes
?70 intercooler
?50 downpipe to modify
?75 fuel rail
?75 cable clutch conversion
=?2000 approx costs
but did have a old cabby lieing about as u do lol so got driveshafts off that
only really need to get a whole exhaust system and downpipe made but what i have made will be ok for time being
it is surprising how much u can re use from old engine setup
also if u used original gearbox and used original 1.8t ecu and clocks and keys u could almost half what i have spent so far i reckon
engine mounts i took the original 8v pressed out bushes as they were good then cut and modified and fabricated new ones then pressed original bushes back in, was goin to replace but a nightmare around here to get them.
strongly considering doing the same with mine after paint.
getting way ahead of myself as I've not turned a wheel in anger in its current guise yet.
Did you say you've got it ging now? any chance of a vid?
DROP THE TOP AND LETS RIDE
