MIG wire feed set up
(In Topic #95024)
Everywhere I read seems to say take the wire out from under the roll of wire, not the top, but it seems better from the top. Just as I seem to have improved the consistency I ran out of gas!!
Anyway, any tips appreciated
One tip could be - unclamp the wire feel rollers and see how easy it is to pull the wire through - it should be easy with little/no resistance. If its not, then you have an issue with the flexi. SIP uses a plastic wire feed inner tube, where most other welders use a metal one. You can swap it, a new inner costs around ?5. But you can't do much with the weedy wirefeed motor.
Another issue could be rusty wire. Maybe its worth unwinding a couple of metres and ensuring its free of rust. In preparation for this, I'm using the little one in the welder day-to-day and I've taken my 5kg reel out and storing it in the dry in the house, so it doesn't rust.
1983 1100 C
1983 1100 C
1983 1100 C
1983 1100 C
1983 1100 C
1983 1100 C
Looked at the motor that drives the wire through the other day - seen bigger motors in radio control cars! Will be changing this next.
Robmk1 said
I have an SIP 150 and its very poor. Like Paul said it seems to be weak. Just converted to euro tourch as well with little improvment.
If you don't mind me asking, how did you fit a Euro torch and did it cost a lot of money to do? I need to sort out a torch on my old welder, then I could sell in on eBay or something. Can't really sell it as-is.
Need a kit like this.
http://www.welduk.com/Details.asp?ProductID=290
I bought mine off ebay as a complete kit for about ?50.
Your case may not be the same though but im sure you could modify it.
I've got a couple of reels - I'll check if any are different and try them
Life Member
A5OPY said
take out the wire feed liner and blow through with compressed air as crud can build up in liner and restrict wire feed, have you changed or cleaned the tip? is tip the right size for wire as it should be the next size up from wire ie 0.8 wire= 0.9 tip.
to be honest no, it's a 0.8mm tip I think on 0.8 wire - didn't realise you could get 0.9?
Shouldn't be any crud in the feed - its new!!
done this with mine which has twisted the feed liner so it only works properly at certain angles
Life Member
Machine Mart do them if you think about it trying to get a wire of 0.8 through a hole the same size will be very tight i did commercial mig welding for 12 yrs and the tips we used were always that one size bigger best of luck.Hairyarse said
So don't give up but feel free to blame your tools every now and again.
Ref the cheaper welder in B&Q, guessing it was a yellow Cosmo unit? The chap I bought my MIG from was ex-SIP. He said the case is the same as the SIP MIG but internals from China and cheaper, whereas the SIP was Italian?
Not sure if true or not, I thought everything was made in China nowadays!!
