Mars red 1600cc GTI
(In Topic #147060)
Mars red 1600cc GTI
Started project ROSIE at last here are some shots of before and during
Untitled by ken 11 12, on Flickr
In need of a little inner wing repair
And I think she will be needing a front panel
Any advice would be greatly received
Atleast the back end of the car looks solid from the photos
What are your plans?
I remember you asked about wings on my project thread, i see why now! But anothere member posted an interesting comment on page 3 of my thread about making pattern wings fit better, maybe of interest to you when you come to get some, if you find you got crap ones like me! Haha
Good luck with it
Rich
The plans is a almost standard restoration maybe some more modern light units. I will be getting the bodywork done first and remove engine before it goes to spray shop giving it a good going over while car is away.
She is going to be used when done just well looked after,
With ongoing smaller work after that ( suspension, etc)
thank lee
Started to strip engine ready for removal before borrowing an engine lift and a mate to give a hand.
One thing we should have done was attach the lift on the far left of engine so the gearbox would hang down at an angle and make it easier to get out of the engine bay.
Spanner trick is mint for removing clutch plate
Empty bay ready for cleaning up
Gearbox off and engine onto stand ready for some attention
I took a bit off the inner edge of the mount piece and also ground the tacks off, releasing it from the wing and adjusted it until it fitted nicely and re-tacked it. I had to cut a bit out of the top to get it to line up nicely around the bottom of windscreen also.
Let us know how you get on
Once the holes in inner wing and front panel is fitted ill fit the wings again and adjust them, thanx for advice ill let you know.
rosie81 said
brings back memories….
does look like a pretty good base car you have there, what are your plans, stock or modded???
good luck and bring on the progress pics!!
The plans are to keep it stock just as new looking as possible, deffinetly keeping the 1.6 engine.
Didn't get a shot of her on the truck as someone phoned me while she getting loaded up.
Not sure how long she will be away as being done In between jobs, so whilst garage is empty I made a start on the engine
Tried to keep parts of a similar theme together
E.g manifolds, cooling etc
Made a list of things I need to recon the engine
Gasket set ; sump
Head
Rocker etc
Gasket sealer
Crankshaft seal ; front
Back
Water pump
Spark plugs
Oil
Oil filter
All new water hoses
Jubilee clips
Thermostat
Both coolant housings
Core plugs 5
Anti freeze
Fuel filter ( have already )
Air filter
V belt
Timing belt kit
New clutch kit ( have already )
New head bolts
I'm not sure on wether to remove the head or not !!!!!!!!
If I do then I may as well get it a pro refurb.
But a mechanic friend of mine thinks if it ain't broke then don't fix it
I'm not too sure at the moment :dontknow:
Been given any ideas on the time scale for welding?
Rich
I used vht high temp paint aluminium and black, but the black was matt looks ok on block but got some normal gloss black for rocker and sump.
Also Rosie is back from welding with new front panel
Went to see a man who can about the paint job he has even lent me a air sander with pads to rub the engine bay down and will then lend me one of his paint guns so I can paint the bay put engine back in then take it to him for the full respray.
So that's now the new plan
Remove front suspension and brake servo etc
Clean and refurb parts
Sand engine bay
Clean and stone chip inner wings
Paint engine bay
Refit engine etc
Take for full respray
Started removing the black wax oil from inner wings today glad ill only be doing this once
Engine looks great, nice to see an alternator painted well, and I was thinking of going matt black on my engine block, definately will now, exactly the look i wanted!
Whats the fit like on your wings?
Rich
I haven't done anything with the wings yet one is still a little out I'm going to let the body shop sort them out I think.
Ive still just got one sitting on the car and the other off, until ive got the engine in as then i'll be hiding the wiring behind the wing.
Keep at it and good luck
