Kamei Retro Racer mk1 build
as i say pull that spade off and jump the coil direct to the battery. if it fires you know its the ign live feed!
the 5th injector that is connected onto the wur and controlled by the k-star was part of the k-star kit by milford electronics and was added by TSR at a later date possibly when the engine was ran in.
edit: i think the coil is an intermotor blue/yellow one:
http://img.photobucket…Track%20Car/DCP_6381s.jpg
just wondering if the brown wire is important and will effect anything if unplugged.
thanks for all the help so far mate
the resistance wire reduces the voltage seen at the coil see, which is required for contact breaker. but electronic ignition needs a full 12v feed to work properly. hence removing the brown wire and jump the coil direct with 12v to test
either way if that is indeed a resistor wire it needs to go
rested a plug against the head and turned it over but no spark?
also tried leaving the king lead close to the head but no spark?
edit: tried that and nothing happened…
Perhaps the coil is just dead, are they expensive and are there different types for a dx engine?
Going to have a look by the fusebox to see if anything is loose, are there any relays in this system mate?
try another tci as well they can fail
if in doubt ask for mk2 16v
