engine rebuild
(In Topic #152482)
thanks
Your engine reconditioners will supply the correct bearings to suit the reground crank and the oversize pistons to fill the new diameter bores.
Also required new during a rebuild are con rod bolts and head bolts as these are stretched and can only be torqued once.
Then the usual, new oil pump, valve guides, water pump, cam belt + tensioner and core plugs.
