Door pillar rebuild - How-to guide with pics!
(In Topic #105554)
I never buy repair panels, just fabricate from steel sheet, which is much cheaper and more satisfying, so here's a little step-by-step guide which may help someone do the same… Took about 2 1/2 hours, though 20 years ago would have taken 2 days…! Practice makes perfect…
As it was
Decided I had to remove the wing so that I could get to all the perforated bits round the front of the pillar.
Start with a piece a bit bigger than you need, bigger only in the direction that it will curve. I.e the vertical dimension is set at time of cutting.
Measure the size of the hinge post and cut a hole accordingly
Clamp it so you can make some of the bends necessary around the pillar
Take it off again and trim the door aperture edge, as you can't do this once you start to weld it on the car
The welded item. Discovered after this that the current setting on my welder was wrong, hence the rather messy result…
Welds ground down
A bit of filler to smooth it off, and now ready for paint. I'll thoroughly spray the inside of the pillar with Bilt Hamber rust-proofer, through a probe. Should be good for a few years…
To anyone considering this, give it a go! On a bit you can't really see it's always worth trying, and you can only get better with practice. Good luck!
82 golf cabrio (long term project)
83 golf driver (now a gti)
87 mk1 caddy
2004 landrover defender
2014 landrover defender
87 mk1 caddy
Galv is theoretically quite a bit more expensive, but I can get stuff from a ducting manufacturer a lot cheaper than mild non-galv from a merchant, and also I don't use it from one year to the next, and normal steel rusts and needs cleaning if left for long periods.
But whatever works for you.
Yradave says relax.
07792646786
07792646786
Given the boxing and thicker plate behind the pillar which supports the hinge posts, does anyone know how one would go about reconstructing this if it was all cut out, and retain door alignment? This has always been a bit of a black art to me. Opinions welcome.
this is how my mate (paul colman of coltec classics) did my hinge on my caddy;
1, hinge totally loose on door pillar
2, hinge and surrounding area all cut out
3, new hinge and surround cut of another car welded in
still trying to come to terms with the door opening and shutting without dropping everytime 8)
muttley racing ftmfw
I used 'cat & butt' for the sunroof replacement, with such a big and obvious area. The plating for the pillar with a skim of filler looks fine for my daily driver 'tidy-not-immaculate' car, though I'd agree that for a show car, where the inside of door shuts are important (… :? !) it would perhaps look unoriginal. Frankly, with the door shut most of the time I'm not too fussed!
