agu engine wiring diagram? help
(In Topic #122981)
Hi i am at the point of re-wiring my 20v conversion at the moment. It in a 1980 mk1 golf. Can anybody send me a copy of the ecu wiring diagram? it would help me alot. also does the Haynes manual have all the info i need?
If i wasnt on the brew i would purchase such a luxury!!
Thanks team.
Thanks team.
yep , mk4 ecu is de-imobilised already.
also do i need a new fuel pump? the mk1 was a carburated 1600 before i put the 20v in.
if so internal or external?
thanks
thanks
mk4 golf haynes manual will have a AGU diagram as for the fuel pump you will need a efi pump wired into the fuel pump relay
ANDY O on club gti does them
I had it done through bedrock veedubs in motherwell ,
id rather use the original ECU to make it easier. I need a wiring diaram tho.
Well if Chuck de-immob the ECU, get him to give you a copy
or get Baz to wire it in mate. best place to start round here
Im thinking of using an external fuel pump, dont really want to open up my fuel tank.
Any ideas on which car i should get it from? I was thinking polo.
PM me your emaill address, what year and car is the engine from? They're all pretty much the same but there are some differences so helps if you have the right one.
I run a walboro 225lph in line pump, about the same size as a gti pump so fits nicely in the standard position.
'81 1.8T
BMW R1200GSA
Caddy 2k 1.8T
BMW R1200GSA
Caddy 2k 1.8T
buy a mk4 golf haynes manual for the wiring diagrams they are very good
