79' resto
(In Topic #114339)
79' resto
i bought this about a year ago. and havent done alot since due to not having alot of space and any power, after a year of looking i finally found somewhere 2 store her. she needs a fair bit of welding so im hopefully getting a welder in the nxt couple of weeks so can get 2 grips with welding
and start getting it all welded up. poking around so far theres a fair bit of rust in the inner wings and odd bits here and there.
her new home:
started taking the sound deading off the floorpans i found the easiest way was to cut it into squares and then use a chisel knife and a hammer to chisel it off, hopefully should get this all finished by the weekend;
her new home:
Wow, long job ahead!
Look forward to seeing your progress, my son has a 79 S1. 8)
Well you certainly have plenty of space! What are your plans for it?
good luck with the resto!!
I'm now mk1less, ahhhhhhh!
Gone but not forgotten;
'83 Schwarze black GTi
'83 Lhasa green GTi
'80 Indiana Red Met. GLS
'83 Lhasa green GTi
Looks like a good project and a good place to work!
good luck mate, take a pic of the storage place in 1 month bet you cant see the floor
Looks good so far 8)
Try a heat gun on the sound deadening on the floors - you may find it easier than chiselling the stuff off. Either way it's a long and tedious process!
HTH
Rich
HTH
Rich
this is after 2 weeks. its already pretty full lol.pbaronmk1cab said
good luck mate, take a pic of the storage place in 1 month bet you cant see the floor![]()
Hairyarse Posted: Fri Jul 31, 2009 6:14 am Post subject:
eventually once the weldings done im thinking of putting either a 2.0 16v on twin weber 45's or a g60 in her, new interior from newton and keep her looking fairly standard from the outside. ive got the mecanical skills of a fish so its probably gonna take me a fair while to learn to weld etc
i got the passenger side footwell clear at last. i found a small hole but its nothing serious. then after getting a angle grinder this week i took the front panel off and cut the battery tray out. the inner wings are pretty shot but ive got a donor shell im using for the panels.
the list of weldings getting bigger!
both inner wings need welding
the fuel filler surround
both rear inner arches
both rear outer arches
hole in pas footwell
new front panel
and a few odd holes here and there.
looks good man
ive just started mine too. (well a year ago)
and havnt got as far as you.
i havnt got the balls to be cutting and welding just yet.
its posts like these that make me want to crack on with mine.
good work man keep posting
