Site log in
Having problems logging constantly having to do the password reset
If I log in in tapatalk then I can't use the PC even with password and vice versa even with auto log in and saved passwords any ideas plus the fb log in won't work
Site log in
Hi,
First of all lets break the FB link.
You will need to remove the vwmk1golf App from your Facebook profile, otherwise it is an aggressive little bugger that will try and revert you to the FB login. On FB on a desktop go to the top right, then settings, then apps on the left. Find the vwgolfmk1 app and remove it.
Next, do a password reset by going here:
https://vwgolfmk1.org.uk/index.php?page=lostpassword
When you login to the normal site - check the box remember me, then yes. Do not use the FB login at all.
When you use Tapatalk - use the same none FB credentials.
That should be you sorted.
Cheers,
Ade
Site log in
Cheers seemed to have worked
Site log in
Excellent !!
Cheers,
Ade
