Which wheel bolts for BBS RS001?
(In Topic #222122)
Afternoon all,
looking for a complete set of new wheel bolts including locking bolts for my Mk1 tintop GTi. Can someone confirm before I order them exactly what ones I need for my BBS RS001's? I currently have standard bolts which seem to be ok with the radius shoulder on them, just wondering if they should be slightly longer than standard?
Peter
Peter
Wheel bolts on bbs ch | VW Golf R32 Forum few bits of old info on here, again seems ideally should be a taper as aftermarket, but if you have option to check with bluing the contact between the bolt and wheel counter sunk hole more contact better than less. if old wheels dont for get the wheel could have had wrong bolts in over the years and the holes maybe distorted.
On the drive
Myvalver 89 GTi Grey mk2 16v
Blu tac em and see.
RS's were dealer options for many manufacturers… so I'm assuming different ones have different bolt seats?
Could be wrong tho…. never been rich enough to own RS's.
Thanks for the advice. I don't have access to the wheels right now, hence my question as I'd like to get the bolts ordered. However, a bit more extensive research seems to indicate the RS001 uses wheel bolt with BBS part number 0923037, which is M12x1.5 with a 60° tapered seat, 28mm long.
Think I will have to wait until I can physically check them, I just thought someone on here would know already.
