Which outer CV joint do I need
(In Topic #187441)
I have a 20vt conversion with the larger 92mm inner flange, does the inner CV joint size effect the outer?
Website Manager
Website Manager
http://www.eurocarparts.com/ecp/c/Volkswagen_Golf+Cabriolet_1.8_1990/p/car-parts/car-transmission/transmission-parts/cv-joint-kits/?657443251&1&c8dd660c1edd04a80507726b78bc78824b2d731f&000095
The spline and hub dia match up, but the overall size of it is alot smaller, my outer dia is 90mm whereas this is around 80mm. The boot is also to fit a smaller diameter driveshaft.
Can you help me which one it is that I need, as this was for a late cab.
Cheers!
http://www.vwheritage.com/vw_spares_CV-Joint-Kit-Outer-90mm-Mk1-Cabriolet-Mk2-Golf-Corrado-357498099_act_shop.product_pID_45300513.htm?crumbStartPage=1
My inner CV joint is 100mm dia and the outer 90mm. Is this correct?
