Which gearbox do I have
(In Topic #205187)
Lemon Yellow Tin Top Restoration
http://vwgolfmk1.org.uk/forum/index.php?page=topicview&id=your-mk1-golfs_2%2Flemon-yellow-tin-top&kfs79=30
cbdubs - yeah that makes sense and if not im sure ill work it out, cheers for the info
rubjonny - haha ill be careful mate, don't want that happening
rubjonny said
as above, plus the housing under the car needs modifying/replaced if going 5 speed so you can get the lever over to 5th
Finally got round to looking into this, I can get 5 gears from the box itself but then when I come to setting it up the gear lever wont go over enough. How do I check if housing under the car is the correct one or what's the mod that needs doing so that I can get the lever over enough to get 5th
More on 4 speed to 5 speed shift linkage | VW Vortex - Volkswagen Forum
@ post 18 there is mention of the lengths.
VW Caddy, is known to me as Missinglinkz I used his short shifter kit, which looks alot like his selector extension for the short shifter…
Hope it clarifies the issue as there is also a side by side shot of the selector lever with the ball differences.
