which alloy and tyre sizes do you suggest for stretching
(In Topic #167428)
thanks for the advice in advance
There's no point stretching a tyre on a narrow rim with high offset.
Website Manager
My previous daily had 215 stretched over 9J and did 20k miles per year. One of my other rides had 255 stretched over 12J without issue.
I plan on running 6.5j with 165/40 on my Cabrio. Other alternatives I looked at were 8J with 195/50. Both are very moderate stretch and in my opinion perfectly safe.
Drifting is a motorsport and you'll see most run stretch as it increases sidewall stiffness.
I wouldnt recommend it though, you seen that video doing the rounds on FB of the mk4 golf? Stretched tyres blowing out on rolling road…. not good.
Tyrestretch.com is your friend for seeing examples.
'83 formel e
arf333 said
there is a website that has examples of wheel sizes with different stretched tyres…. hundreds of combo's & theres photos for each one. i cannot remember what it is though
Do you mean the mk3 golf? and if thats the case that had zero to do with stretched tyres and more to do with having a guise and doing a top speed run.
Probably not advisable with a 24v vrT running 550bhp and a 6 speed box with select diesel internals but the attempt was for fun and it was the Falkens speed rating that was the issue NOT the stretch
jaaquo said
so what would you class as a moderate stretch? being ratio between rim width and tyre width and aspect ratio?
10% is moderate in my opinion. On a 8j rim I wouldn't want to see less than 185 for daily use although if you went with a higher aspect ratio say 50 and above 175 may be acceptable.
You need to look at the brand of tyre too. Nankangs are very popular for stretching and they also come up narrow compared with other manufacturers so take that into consideration. It's my brand of choice for stretch. Falkens are also good but a bit more pricey.
The biggest thing to remember is to run the correct tyre pressues. On a XL rated tyre I wouldn't want the pressure to dip below 38psi, more over I'd like to see it around the 42psi mark.
Not sure i didnt watch it it looked like a blue mk4. video was called "stretched tyres fail on dyno"
jaaquo said
excellent thanks for the infoill have a look at that website. when u put the "J" after the number is that representing the width of the rim in inches?
The 'j' refers to the shape of the wheel where the tyre bead meets it.
http://www.carbibles.com/tyre_bible_pg4.html
Please read the above for all your wheel and tyre questions!
