Vectra Brake advice
(In Topic #218598)
Torque setting should be fine as I imagine it's the original bolts into the original holes? If so it's fine as the torques are there to avoid over tightening as well as under tightening. If you're concerned then use a bit of thread lock.
Yup you should have anti rattle thingies I'd have thought but see how you get on. Did any come with the pads?
Sliders, you could use thread lock, it won't do any harm but if torqued correctly they should be fine.
Ian
Vectra Brake advice
