No 1st and 2nd Gear
(In Topic #243560)
Has anyone experienced this? Would I get this issue if the gearbox oil is low?
Attached are a couple of pictures of where the gearbox is wet with oil. I assume the sensor is the reverse light switch (not sure the reverse light is working). The torx bolt is on the front of the gearbox casing, I’m not sure what exactly this is for
would lose a gear or three.
Hear is a linkage adjustment guide, and It Probably wouldn't hurt to look at and replace the engine mounts as a bad right side and rear mount can cause shifting issues as well
Guide:
https://www.cabby-info.com/files/transmission/ShifterLinkageGuide_5speed.pdf
