Brake conversion to mk2 GTI
(In Topic #220090)
I'm doing a conversion (brakes and engine) from a Golf mk2 GTI 16v on my -87 cabrio but I'm missing the front brake caliper carriers (for 256mm discs). I have heard that one can get the carriers from an Audi and want to ask if any of you know what model and where to buy them?
// Viktor
Skickat från min ONEPLUS A3003 via Tapatalk
VAG part number 853615125, TRW BDA145
Re:
Thanks for that! Now I know what to look for.rubjonny said
early square shape audi 80, or scirocco 16v. either way, not so easy to find.
You can easily tell which you have, it'll either have 'VWII' or '54' cast into the caliper
Re:
Ahh, I'll look into it. Is there any known performance differenses between VWII and Girling 54 brake caliper?rubjonny said
mk1 1.5-1.8 use the same 'VWII' type calipers as found on the mk2 1.6-1.8 8v and 1`6v up to around 1988. later 16v use a different caliper 'girling 54'.
You can easily tell which you have, it'll either have 'VWII' or '54' cast into the caliper![]()
